RE: Engine Cutting Out
Thunder Tigers don't have those silly rear needle valves & they seldom suffer from carburation problems. Assuming that the clunk is not stuck at the forward end of the tank (you did hold it nose up & give it an almighty shake up & down didn't you?), my guess is a pinhole in either the clunk line inside the tank, or the feed line from the tank to the needle valve.
