RE: Anybody using Amsoil 100:1 with their FPE 3.2 engine?
In that case, mixing 30:1 or 50:1 would be preferred, and Amsoil 100:1 allows that.
I quote from the Amsoil web page:
[link=https://www.amsoil.com/images/2cycle_chart.gif]Saber? Professional Synthetic 2-Cycle Oil[/link]
Designed for premix applications as lean as 100:1 ratios. Richer mix ratios may be used when desired. Saberâ„¢ oil improves throttle response, lowers or eliminates smoke, controls deposit formation, and lowers emissions. Saberâ„¢ Professional has a performance emphasis on hand-held power equipment such as chain saws and lawn/utility equipment. ISO-L-EGD, JASO FC, API TC
Maybe for the 30: 1 mix: (OK for Zenoahs etc. I would not use this oil for cantilever crank designs like DA, MVVS, RCS, Moki etc)
INTERCEPTOR Synthetic 2-Cycle Oil
A high-performance two-cycle oil with a performance emphasis on exhaust power vales. Excellent for all types of snowmobiles, motorcycles, personal watercraft, ATVs and jet boats. Contains high levels of detergent additives to prevent valve sticking. High quality replacement for manufacturer branded oils. Injector use or 50:1 premix. JASO FC, API TC
