RE: Aileron ID made foolproof
I use a strip of covering material of different colors around the base of each part of mating plugs. Or you can use small, colored zip-ties around the wires at the base of the plugs. Or if you're really paranoid, reverse the plugs on one side, so one wing is male and one wing is female.
