RCU Forums - View Single Post - Profile Setup
Old 04-29-2005 | 05:02 PM
push rodz's Avatar
push rodz
Default RE: Profile Setup
Just for grins.....why not set your ailerons where they are supposed to be (in-line with the center line of the wing chord)...? If you want flaps or its effects - why not just add flaperons to the mix.....?
Adding down thrust to your engine would be a good place to start to counter act the plane wanting to climb at higher throtte levels and then go from there. It's kind of a process of elimination........
Good luck!
