RE: Carb won't close down -- What's wrong?
OK. So I'm an idiot. I just discovered the idle set screw and it was WAY loose!!! A few turns and things were OK again. I assume you tighten down the little nut underneath the screw head to lock things down. I imagine a little locktite would be in order to.
I really do have to establish a better routine for pre-flight (and post repair) checks.
