RE: how do i set up elevlons on a wing aircraft?
So you get the proper for the aileron action?
If you go left stick, does the left aileron go up and the right one go down?
If not, reverse both servos and see if that does it. If not, remove the reverse.
Now, switch the two servos. That is, swap what slot the are plugged into in the reveiver. Now try it. If it is still not right, reverse both again.
You usually have to play with them a bit till you get the right combo of reverse and receiver slot. Be patient.
