RCU Forums - View Single Post - Taping down Receivers
Old 04-30-2005 | 05:01 PM
Montague
Default RE: Taping down Receivers
In theory, no, it's not enough for a glow or gas engine.
However, RX's are better than they used to be. I've seen many mounted with less padding than you describe and not have any problems at all. I doubt you'd have a problem.
Just do the best you can, and remember that if it does fail, it will cost you a lot in terms of the destroyed model. So extra effort to get a better installation is well spent.
I've done things where I had padding top and bottom, but nothing touching on a side for example.
