RCU Forums - View Single Post - Using Latex Paint - Help
Old 10-03-2002 | 02:37 PM
k_sonn's Avatar
k_sonn
My Feedback: (32)
Default Using Latex Paint - Help
Jim:
On both Tmoth4's plane and my plane the paint was not clear coated at the time it had turm gummy. Tmoth4 cleaned his up and clear coated it after it had gummed up. I stripped mine down to the primer and repainted it. I have to put the detail work back into mine and then I will clear coat it. Like I said in an earlier post, I am not putting the Behr product down. I like it and will probably use it again, but I will clear coat it before gas gets near it. Beings others are not experiencing the same problem, I feel that it is probably not the paint, but instead, some other factor like the brand oil added to the gas or the brand of gas. I used Cheveron brand gas. Each brand of gas has different additives in it. I just chalked this one up as a learning experience.
Branded:
I thinned the paint with windshield washer fluid and I did not use Flotrol.
