RCU Forums - View Single Post - Diff Replacement...Skill Level?
Old 05-01-2005 | 03:59 PM
ncgrunt
Default RE: Diff Replacement...Skill Level?
There is one shim in each diff case, on one of the outdrive bearings. All you need to do is check the gear mesh after you transfer everything to the new cases. If it's not smooth, move the shim to the other side and if that doesn't fix it, remove it entirely. The shim is clearly shown on all the exploded diagrams of the diff's.
