RCU Forums - View Single Post - stroke of good luck
Old 05-02-2005 | 09:44 AM
txaggie08's Avatar
txaggie08
Default stroke of good luck
well i ahd a stroke of good luck last night. Im about 2/3 done with the framing on my kadet seniorita, and a friend came over to see it. He has an older trainer(no idea wich one) that got broken before it flew(broken tail feathers......should be an easy fix. few cents in balsa and som epoxy). He says i can have the plane. so im going to have two trainers that need a little construction to be flyable.
now my reason for posting. I dont know wich one i should use first. the second plane has ailerons, so i was thinking i would convert it to a taildragger to use as a second plane. im not shure though. what do yall think,should i keep bothe as a tric gear and switch between them training, or convert the second plane as a step up in difficulty from the tric, no aileron, seniorita?
