RE: CMPro/Chief/GSP 72.5 Extra 300s Build thread
Hey Lawrie,
I will take pictures tonight of the stab and post them here tomorrow. It's only a suggestion, but I wouldn't put a steel mount in the front. If you want to go all out buy a great planes mount. They are heavy duty.
If space is an issue you might want to set up the stab to be removable. It's pretty easy to do just put the bar in the the stab then line up a small drill bit and drill one side first. put midium CA in the hole. Let it cure for about 2 minutes and then put the bolt through it and forget about it. The second hole you can use liquid locktite if you want. That will be the one you screw in and out at the field. Or you can use loctite on both of the bolts. It doesn't matter. I forgot to tell you that the motor was spinning close to 11,000 rpms that I had to richen it upand it dead sticked yesterday. But it floated down..It did not sink. So I know that it's not heavy, I just don't know what the weight is. I will try to weigh it sometime this week.
