Since you never mentioned what size I will assume 40/46 size. One of the best all around 2nd type planes I would suggest is the Goldberg Tiger 2. You can build it as trike gear or tail dragger. One thing to note that seems to be a common goof in the ARF vsersion from the factory is that the hole for the throttle cable is predrilled on the wrong side of the firewall. Not a big deal, just drill a new one on the correct side and seal the original hole with epoxy. The rest of the plane is nicely designed and the plane flys really well.
