RCU Forums - View Single Post - Differential Ailerons on Pattern Airplanes
Old 05-03-2005 | 04:14 AM
stek79
Default RE: Differential Ailerons on Pattern Airplanes
Guys,
this problem is making me crazy ...
Perhaps I have done a little step forward toward the solution, or at least we can say that thrust line is not a player in the problem.
Infact, some pilots suggest to check differentials on a vertical dive WITHOUT throttle. I tried with my plane, and of course I found that even these diving rolls were good as a climbing one with full throttle...
So it seems that thrust is not an issue.
