RCU Forums - View Single Post - Four star build
Old 05-03-2005 | 07:37 AM
  #47
MinnFlyer's Avatar
MinnFlyer
Default RE: Four star build
Here is how I would do it,
make a 1/8" Plywood plate that will fit between two ribs with a hole cut out for the servo
Glue it between the ribs about 3/16" below the surface and reinforce it with Triangle stock.
Using 1/4" stock, build a box around the servo cutout - About 1/8" larger than the cutout on all sides.
Sand the tops of the box even with the ribs (Be careful not to sand the ribs - taping some tin foil to the tops of them is a good way to keep from saning into them)
