RE: cutting pushrods
Best tool I have is the Dremmel tool. The problem with pliers is that they tend to flatten and widen the wire as it cuts it so you end up with a cut sharp edge that is rather flat and wider than the original wire was. The dremmel will cut through nice and you can then touch up the ends to round them or taper or whatever but they will remain the same diameter at first after cutting.
