RCU Forums - View Single Post - Engine bogs down on steep climb
Old 05-03-2005 | 11:48 AM
Scar's Avatar
Scar
Default RE: Engine bogs down on steep climb
ORIGINAL: akschu
I have a tower trainer and a OS .46 FX and a 11-6 prop. When doing a steep climb I can hear the engine slowing down. Is this normal? Should I be running the engine leaner or go to a smaller prop? If I load it too hard will the engine stall?
schu
The .46 FX with an 11-6 will be a little overpowered on a .40 size trainer. I would not expect it to ever die in the air, in a steep climb. A minor change in the tone is to be expected.
Are you flying it wide open? If so.... why? I could understand if you were flying at about 30% throttle, and the engine tone changed in a steep climb, but there should be no fear of engine stopping.
In my opinion, your trainer time is best spent flying around at about 30% throttle, except after you have progressed to the aerobatics practice stage. At that point, I see no need to fly at more than 30 % throttle except when preparing for a loop, or climbing into a stall turn, or other aerobatics.
At no time would I anticipate that a properly adjusted .46FX would slow down anywhere near quitting - especially not when throttling up and entering a loop or climbing into a stall turn.
If that's what you're doing, and the engine is slowing excessively, I suggest your high speed mixture needle is not adjusted properly - or there is a fuel feed problem.
Good luck,
Dave Olson
