RCU Forums - View Single Post - ultrastick help
Old 05-03-2005 | 02:56 PM
Ernie Misner's Avatar
Ernie Misner
Default RE: ultrastick help
I installed my Sullivan bracket real easy after the plane was built. I glued a piece of thin plywood onto the bottom of the tail section so that the screws would have something solid to screw into. Since the bottom of the rudder is a bit too high, I glued a little balsa block onto the bottom of the rudder, and used that as a mount for the Sullivan steering spring wire to fasten into.
Ernie
