RCU Forums - View Single Post - cutting pushrods
Old 05-03-2005 | 04:09 PM
bruce88123
Default RE: cutting pushrods
If you can find a pair of pliers with a screw cutter area, then you can use that part to do it. make a fairly good shearing cut. Use the smallest available hole that the pushrod will fit into. Best choice IS the Dremel though. They are hard to plug in at the field but there are battery powered versions(never charged when you need them). []
