RCU Forums - View Single Post - Sig Hog Bipe Build
Old 05-03-2005 | 11:58 PM
  #234
jspencer's Avatar
jspencer
Default RE: Sig Hog Bipe Build
fred123 that is just the opposite direction of what I did, but same line of thinking, if that makes any sense. Looks like you will have your bird in the air in the next week or two.
I just finished sheeting the turtle decks, took about 1/2 hour to form the sheeting and then just waited for it to dry and cut it to shape. To get the sheeting to form to the shape I just ran warm water over it for a couple of minutes to get it good and soaked, then I started shaping the sheeting a little with the warm water running over the sheeting. After about 3 or 4 minutes I had the sheeting to the shape of the deck, then just taped it down and let it dry. While it was taped down I marked the point on each edge where I needed to cut the sheeting, cut it and glued it down, piece of cake. This was the first time that I tried this and by far has worked the fastest and the best.
