RCU Forums - View Single Post - Rudder pull pull dimensions
Old 05-04-2005 | 09:26 AM
bigcam
Default Rudder pull pull dimensions
I am looking for some help with a dimension for the set back, or forward of the rudder horns on the following set up. Servo horn= 2in. Rudder horns 2 5/16. wires are 23 1/4 in long and the wires are CROSSED! What dimensiuon do I need to have the wires not tighten or loosen as the rudder deflects. Rudder throw is approx 45degrees. Any help is appreciated. The horns are currently on the hinge line and the wires loosen at full deflection.
