RCU Forums - View Single Post - Sig Hog Bipe Build
Old 05-04-2005 | 10:36 AM
  #241
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Sig Hog Bipe Build
on the headrest. I did the same thing and carved one out of balsa. I HATE plastic on my planes. So I did the same thing Jspencer did and carved it from balsa. After you get it carved use a dremel to carve out as much of the inside as you can. It will make it easier to mount, and save a small bit of weight.
on hinges. On my Hog I used CA hinges and then I sealed both sides of the gap with monokote. I've gone away from using CA hinges now (I use Robart hinge points now), but I still seal both sides of the gap with monokote.
