RCU Forums - View Single Post - Sig Hog Bipe Build
Old 05-04-2005 | 01:05 PM
  #244
fred123
Default RE: Sig Hog Bipe Build
RCKen: Help, Help...Do you have any tricks for installing the windshield?. I am using formula 560 glue and have cut out a 1/16inch strip of covering to give the glue contact with balsa. Looks like I would only need to clamp it on the very tips for the glue arc to make contact. However, it turned into one big mess with glue everywhere.. Thank goodness it is water soluable. The Plexiglas is so springy it is very difficult to hold in place.. What about a screw at each point of the windshield, or is there a way to form the Plexiglas so that it would hold its shape? Fred123[&:] P.S. Tried the screws, and they worked great.. Sometimes it helps to talk about ones problems...Fred123
