RE: Sig Hog Bipe Build
Hey Guy's I have a question. On the windscreen, I was having the same quetions, but have thought of a way that might work to hold the thing in place. What if I were to leave a square tab of the clear on the outside edge of the windscreen, cut a small slot in the balsa for the tab to be slipped down into, and then shoot some CA in the slot? It would be something similar to the cabane struts where they go down into the side of the fuse. It is just a thought, but I might try it...just wanted to see what you think.
BTW: Can't remember who asked it, but it was on how I was going to run the antennae for the RX. I am mulling this over right now and may just run it up straight through the headrest block then back to the vertical fin. I think this would give it a realistic appearance based on the type of aircraft and the time it represents. If I don't do that, I will simply bring it out the bottom of the fuse in front of the tailwheel assembly.
