RE: Sig Hog Bipe Build
Hooked,
The only problem I can see with the "tab" on the windscreen is you need to seal the front of it, otherwise th wind is going to try to lift it up and tear it off. That's why I put the monokote on it to seal it down. I've been using monokote to attach canopy's for about 6 years now, probably 8-9 different planes. Never had a problem.
