RE: control throw
Try reducing your control surface throws. Move the linkage IN on the servo arms and OUT on the control horns that are on the control surfaces.
With reduced throws, the plane will not be as sensitive. As you gain experience, you can start moving the throws so you have more movement on the control surfaces.
