RE: Are any of you not using a Matchbox or programmer
While it may not be popular, I'm doing just that with no problems. I have 5955's. Word out is "DO NOT PROGRAM THEM" until Hitec has a fix. Soooo, I took the 6 I purchased and plugged them into the Rx, making two pair out of the 4 that were the closest match on center. Make sence? Then I installed them on the wing making sure my linkages were matched mechanically. Each servo has the same throw and if there is any misalignment (very small if any), the aileron will flex enough. My servos are 30" apart.
50 flight, 0 problems.
Ryan
