RE: Tower Hobbies Voyager , need help
Gentlemen,
Thank you for your advice. I like that idea of swapping the carb around. I'm wondering if you were able to reverse the slide in the carb body so that the fuel nipple is still pointed aft, but the link is reversed? That would be trick. If it doesn't work, I'll just have to be careful and move that pushrod over and possibly reverse the servo in its mount. Should be "fun". Next time I shop for airplanes I'll look into the engine mount closer! (Its a Thunder Tiger pro 46 engine, btw.)
Thanks again,
Jack aka 3wire
