Programming question
In JR 6102 manual page 72 they say following. "The XP6102 offers two (2) separate throttle curves with five adjustable points per curve.
This function allows you to customize the throttle curve and pitch curve together to maximize engine performance at a particular pitch settings.
Once the throttle curves are established, each can be activated in flight using the two (2) position flight mode switch"
Ok ok now i lost track [:-] Where or which is that position flight mode switch? And how i set up that?
Best regards Nobler
