RE: JetJoe OWNERS thread
No you can't adjust pump voltage past the start ramp proceedure. If it more than likey the FADEC on Luis's motor with eratic RPM readouts which will quickly be diagnosed and repaired. With the Stock pump you may have to run a pump ramp as high as 15 for fast startups where the FW pump is around 5.
