RE: cmp p47 thunderbolt
Thanks for the feedback seahawk, I solved the split elevator problem. I glued a plastic guide on each side of the elevator pushrod at the first bulkhead. The two guides stop any significant side to side movent without adding much in the way of drag on the pushrod. I really don't want to add more weight to the nose, but you think I might still be tail heavy?
