RE: Are any of you not using a Matchbox or programmer
I put 2 HS 5945s in each wing panel in my Comp-Arf 2.6 Extra330 L with no match boxes or programming. I carefully adjusted the throw on each servo and used heavy duty Y extensions. At this point I have more than 150 flights with not a single problem. This set up is running so well that I kept it the same on my 14mz.
jef
