RE: Tower Hobbies Voyager , need help
I have the Thunder Tiger four stroke 91 and it is just like any other 2 or 4 stroke that I own. That is the carb is reversible from one side to the other. You may have to use a reverse setting on your servo so that full open is different but most transmitters are capable of this also. Another alternative has already been suggested to you and that is to use cabling and pull pull setup. Either one or both combinations will work. The choice is yours to make.
