ORIGINAL: Angst
When you rip apart the diff, you might want to put in an aluminum diff; it'll last much longer.
From my expierence with the metal diff it is only good if you buy the other gear in metal with it too otherwise you will just keep screwing up that gear. Like said before you would than have to replace the balls instead. Whatever works for you.
