RE: 1/4 SCALE CAP 232 FORUM
Fencemagnet, What is your e-mail address? I have the manual for the 120 size 73" H9 CAP 232 in .pdf format.
3D Joy: I may try the expo, but if I make it richer on the high end, I get less rpm than before. I actually flew it richer on the first flight than the second and the performance increased when I leaned it out a bit.
I'll try the APC 20x8 prop and re-check the timing on the ignition sensor to make sure that's good to go. Also, this thing is so nose-heavy that it doesn't want to stay on a vertical line too long, so I may also move the cg back about 1/2 inch and see if that makes it a better flier all-around.
Rich
