RCU Forums - View Single Post - What is new at Superman?
Old 10-08-2002 | 03:06 AM
  #43
BernieG
Default Re: PCM Question???
Originally posted by Dustin Buescher
When a PCM radio gets interference from some source, if the interfering signal is strong enough, it will go into the pre determined fail safe??? am I correct?
Yes, you understand properly, or close...I don't think it has to do with the strength of the signal, it has to do with the decoding from the receiver. If, for whatever reason, the receiver is not able to decode the coding from the TX, it will go into failsafe, after a certain delay.
Now, what happens into failsafe, depends on how it has been programmed, or not. On my case I related previously about the Maverick, it's partly my fault, as too new to PCM I had NOT programmed servo positions in fail safe, and as it was a second hand receiver, I am pretty sure my servos went into whatever was programmed previously ( or not).
With my actual IPD receiver, it's so easy to do that it is done...
Bernard
