RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 05-06-2005 | 10:43 AM
  #2052
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
hockeyrules99... No the fuse is just the basic stick/covering ARF.. There
is a lot of cut-outs through out the fuse... Seems to be built good, the
push rods are kinda thin... If the plane makes it through it's first flight
and it flies ok, I'll get stronger ones.. Yeah it's almost(looks) like the
morris hobbies plane with almost the same color scheme.. Hey, for half
price I went for it... It's close to being finished, if all goes right maybe I'll
try it tomorrow or on Monday... Maybe.. I hate to drill it out for the FX
then get the YS... On the, slide the wing on and apply a bead of med. CA
That's what Kangke wants and I ended up doing it that way... Hey I pulled
and twisted the wing and it ain't moving??? We'll see.. They said to do the
same on the stab., But I'm going to do that the normal way.. It's not in
cased like the main wing...
sctcrash... You really can't beat better servos.... Centering, speed etc.
things that you think won't make that much of a difference... But on some
maneuvers you will see how much better they are.. On my first flight with
my used UCD I actually used my "trainer" onboard system with the standard
bushing servos... Then when I got the system I have now.. I did notice the
difference, it just made things eaiser... I really notice the difference on the
Rudder with the higher torq./speed it just responded smoother and quicker
which for me made hovering it so much eaiser.. If your also getting a
charger for you six volt.. a Nimh is better than Nicad..... Lets not even get
into the high tech battery..... Well again that's my story and I'm sticking to
it:-)
Barry..... Yeah I know[:@]...... Don't test it then itch your forehead:-( Don't ask
Have a Great Day people
..... Darn Wind.......
