RCU Forums - View Single Post - Protecting balsa from heat while soldering cabanes & interplane struts
Old 05-06-2005 | 12:38 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Protecting balsa from heat while soldering cabanes & interplane struts
Mindwarp hit the nail right on the head. A metal clamp or a vise-grip pliers work great, clamp them as close to the fuselage as you can. This will act as a heat sink and keep the heat away from the wood. If you are worried about solder getting on the wood, get a small sponge, wet it, cut a slit in it and slip it over the wire to act as a shield for anything running down the wire.
Hope this helps.
