Biplane Problems
My guess is you're having to fly around at almost full throttle all the time? If so, it's probably not a thrust issue, but one of speed, and you need to try a steeper pitch prop. I've got a plane with similar characteristics and if I go strictly for thrust, I run in to the same problem, but with the right prop, she'll carrying through extended up lines quite well.
