3w 42i
rc bugman
I was using a MAS 20x10 wood prop and managed to get up to 6500 rpm with that prop. Regarding the fuel that cames out of the carb, there must be something that can be done, i spoke with the local 3W agent and He told me that there wasn't enough air getting in the airframe and the engine was running rich that i had to make wools at the back of the fuse, others told me to build a box around the carb and make a 50mm tube to bread air from underneath the fuse. I haven't tried any of this options so far but the inside of the plane (receiver, servos, batteries) are getting very oily. Elson do you just leave has it his ore have you done something about it?
Tiago
