RCU Forums - View Single Post - Morris Hobbies Knife ARF
Old 01-01-2002 | 10:06 PM
BALSA BANDIT
Default Morris Hobbies Knife ARF
I fly a MORRIS KNIFE and if the arf is anything at all like to built up model, you can't go wrong with this plane. Hardest thing to do is to trim it out on it first flight. Only way it gets done without crashing is to lift it off the ground and get up about 100ft. and pull back on the power. Now you can adjust the trims without putting it into a pile on the field. Ken....The "BALSA BANDIT"
