RCU Forums - View Single Post - Strating options
Old 05-07-2005 | 03:13 PM
rushdude's Avatar
rushdude
Default RE: Strating options
ORIGINAL: Bcamos
Get a starter box. Less requirements.
That would be the best idea. I use a starter box. If you use you cars only at home just use a 12 volt battery charger (usually for real cars) to work the starter box instead of buying bateries. Just make sure the charger is at 2 amps and that you have it unplugged when you aren't using it. That is if you are on a budget.
