RCU Forums - View Single Post - IS 8.2V MAX NORMAL FOR LITHIUM USING SCHULZE?
Old 05-07-2005 | 04:41 PM
jooNorway
Default RE: IS 8.2V MAX NORMAL FOR LITHIUM USING SCHULZE?
As far as I have read all the recommendations from the LiPo-producers they especially warn against charging LiPo on LiIon-programs. This due to higher internal resistance in the LiIon-batteries. The other way I don`t know, but remember: the recommendations and warnings are there for your safety and to avoid accidents...
Run your batteries, allow two break-in flights letting them rest 15 minutes between some 5 minutes duty-time, charge them as recommended when empty and check how much mA they will charge in...at LiIon-program. If this seems OK then batteries and charger works OK. If not do not try to manipulate things.
