RCU Forums - View Single Post - Bump without glow plug, is it normal?
Old 05-07-2005 | 04:55 PM
Motorboy's Avatar
Motorboy
Default RE: Bump without glow plug, is it normal?
The sleeve are tapered and the piston are tight in TDC, it is normal for ABN, ABC engines. When the engine are running, the sleeve will be more cylindrical.
In case there are crankshaft bended...
Have you tried to rotate the crankshaft without piston/sleeve?
Jens Eirik
