RE: Titanium Shafts
What was it that was causing the poor steering? If you had the hubs screwed in too far it reduces the steering quite alot. Just check that the hexagonal screws above and below the hub are allowing enough movement to steer properly. If not, loosen them and this should also ease the tension on the cvd. Just a thought.
