RCU Forums - View Single Post - prop question
Old 05-08-2005 | 12:06 PM
DMcQuinn
My Feedback: (13)
Default RE: prop question
Generally the advice is to never use a nicked prop. Your nick sounds pretty small. you might want to check the balance. the nicked side may be lighter than the good side. Even up the balance by sanding some off the good side. If you do use this to run-in your engine, just make sure to never get in the path of the prop -- stay behind the arc of the prop.
