RE: prop question
If the nick is big enough for you to question, and you can see it, then DON'T use it! It's not worth the risk. Go get another one and then break in your engine. I mean, does the thought of a few inches of plastic being impalled in you sound good? Not worth the risk--especially when breaking in the engine since you will obviously be very near the engine at all times while it is running on the ground. JMO.
