RCU Forums - View Single Post - Powerline Hobbies Edge 23%
Old 05-08-2005 | 03:49 PM
  #63
RysiuM's Avatar
RysiuM
Default RE: Powerline Hobbies Edge 23%
ORIGINAL: RysiuM
I found, that tail servo wires with 24" extensions are bouncing around the fuselage so I made simple paper tube glued in the tail part.
"Think twice before you do something" - I had to move tube lower in the fuse because it interefered with pull-pull wires. No big deal.
I used stock wires but two things I noticed. Wires are a little (like 1/4 inch) to long. I replaced clevises for servo with the shorter one, and I turned servo around. I used original horns (they are only 2 grams heavier than mine) as all fit right out of the box. No need to change it. Slots in the fuse are already cut and everything is perfect - I admire Powerhobbies for excellent design.
One small thing tho: Pull-Pull setup would be easy to setup it the left servo block didn't interfere with the wire. The left elevator servo front block extends down blocking the wire. I had to cut it - a little difficult to do it reaching there with exacto knife throuh servo hole.
RysiuM
