RCU Forums - View Single Post - Diff Replacement...Skill Level?
Old 05-08-2005 | 08:55 PM
  #55
ncgrunt
Default RE: Diff Replacement...Skill Level?
All you need is the oil. There's a gasket in the ring gear and an o-ring in each outdrive to seal it. I just wiped out as much grease as I could and used kerosene to clean them out completely. Fill them up to the top of the bevel gears... some will probably squeeze out when you put the ring rear back on.
