RE: 3W 106 Temperatures
Temps are only good if you take them when running and under the plug with a couple. Different surfaces will also reflect differently, causing abnormal temp readings too.
If you have your engine baffled and not lean you should not have a problem. Listen to it when it runs and that will tell you more than any temp gun made.
If you really want to get fancy run exhaust temps when you are flying and adjust the needles accordingly.
