RCU Forums - View Single Post - FAST WM MIDGIT MUSTANG
Old 05-08-2005 | 09:31 PM
Cyclic Hardover's Avatar
Cyclic Hardover
Default RE: FAST WM MIDGIT MUSTANG
Here is mine. I changed the location of the gear and recovered. Also up in the front is an OS 1.08. A bit of an over kill but plenty of power. Speed is good too. Whatever you pick, your prop will be the key. Keep your pitch number close or the same as the length like a 13/12 or 13/13 or 14/12 or 14/14. I also suggest you use APC.
One bad habit on mine which is obvious from to much engine is you need to have some good elevator control on takeoff or it will nose over. It's quite a balancing act. Also make low approaches when landing. They like to come in hottttttt.
